Masonry openings for windows?
How do you show a double hung window in a masonry wall. In the interior it is 2'-11 1/2" however the exterior masonry opening is 3'-2" and indented 4" for the brick. How can I show this without creating two separate walls. Thank you.
3 Replies 3
pretty sure you won't do this using standard window parameters, so:
use a slab or wall to SEO out the oversize outer opening. should work
bill
sorry
SEO's don't work for standard plan views
bill
Purchase Dimensions Design Group D3 Smart Parts. Their doors and windows allow masonry openings, Brick sills, stone sill, etc etc. All updated and working nicely with AC 8.1.
Check them out at
http://www.ddgi.com/
