Master Layout Settings
Is there a way to apply the Master layout setting from one project file to other project files? I am working on a master planning project where each building type will eventually be plotted as part of a larger set. Having one Master Layout that i can use on all would be very helpful.
Any suggestions?
TomWaltz
One way I know of would be to make a separate PLN with only layouts that has all the layouts for the entire project in it.
Another would be to make a library part out of it so you can edit it once and have it appear everywhere....
Maybe another would be to make a 2D detail out of it and link it into multiple books...
Tom Waltz
Djordje
Any suggestions?
Use the Organizer.
Look here: http://archicad-talk.graphisoft.com/viewtopic.php?t=13038
Search first, ask later.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
