2006-06-07 11:25 PM
2006-06-07 11:47 PM
2006-06-07 11:55 PM
2006-06-08 12:04 AM
2006-06-08 05:18 PM
Mike wrote:I did not have the same from 9 to 10. But if it is those blocks from 9 you are looking for just open the master in 9 and copy and paste it to the 10 layout. This is what i did and it works like magic. If you need to set up printer/plotter margins go into the master settings and on the size paper drop down scroll up to the import from printer/plotter and use it. It is a miracle worker I tell you. A true miracle worker.
These need to be set up as masters. If you had it in 9, you have it in 10. Open up one of your previous layout books in AC 10.
2006-06-10 05:33 AM
jcude wrote:Why?Mike wrote:I did not have the same from 9 to 10. But if it is those blocks from 9 you are looking for just open the master in 9 and copy and paste it to the 10 layout. This is what i did and it works like magic. If you need to set up printer/plotter margins go into the master settings and on the size paper drop down scroll up to the import from printer/plotter and use it. It is a miracle worker I tell you. A true miracle worker.
