2010-08-02 04:20 PM
2010-08-02 04:33 PM
2010-08-02 05:28 PM
Matthew wrote:Thanks a lot.
Sure. The easiest way is to use a PDF or TIFF of the master plan as a material texture and assign that material to a big ground slab or terrain mash.
2010-08-03 05:27 PM
spacytime wrote:I've found part of the solution : for the scale, one should mesure the size of the terrain (XY) and when you save it as a texture, choose 1x1 and put the dimension XY.
...But I find it difficult to control the scale. Should the slab be the same size of the image in PDF / tiff or inverse or the 2 should match exactly?
The resolution is not good : how many does one assign in order to get a nice image ?
2010-08-03 06:38 PM
2010-08-04 11:27 AM
Dwight wrote:Cool, I've made it !
The "Align 3D Texture" Command
