Paul Adams
Matching cover fills on slab
I am having trouble with getting the cover fill to display on one of my slabs. I match the properties with a slab at the same elevation and the same layer, yet one displays the cover fill as expected and one does not in plan view. I checked the settings dialog box and they appear identical. The fill DOES appear in 3D on both slabs.
Thoughts?
Paul
Note: WinXP Pro, AC10, build 815
Paul Adams, AIA, LEED AP
AC17
iMac, 4G RAM
MacBook Pro, 2G RAM
Could there be something on top of the not-working slab that is hiding the pattern. You may also try updating your AC10. May not be the problem, but it might not hurt either. Good luck!
Djordje
Thoughts?
Paul
Hmmm ... why 815? The current is 1183. Help/Check for updates.
Check whether your slabs have the cover fill of the top material or specified seprately.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
