Material editing for Curtain wall
With curtain wall tool can we edit different material?
For example:
Wood for profile for construction,
Alluminium for bar
Thank you for your kind help.
11 Replies 11
Laura Yanoviak
Peter wrote:
I'm getting a strange sense of deja-vu here! This thread is nearly word for word identical to this thread! Even the modifications to the library part are the same!
Well, it was a pretty easy fix! I wasn't aware of the trouble he was having -- thanks for posting a more detailed explanation.
Thanks Laura and Peter.
I have solved the problem through your help.
I couldn't imagine, curtain wall tool is the part of library.
Since lcf. file it is not so easy to find out some elements from library.
I have changed the file (I had to change two parameters.) and it works fine.
It has taken several days.
GS had to do this one as standard.
Sorry for this forum that I took twice for the same problem.
