Mavericks Compatibility
Will Archicad 16 run in Mavericks? Can I just upgrade without fear of some weird behavior?
I'm still in OSX 10.6.8.
Thanks for any thoughts.
7 REPLIES 7
We are looking for the answer to this as well. We are operating Archicad 17 and would like to upgrade to Mavericks as soon as possible, especially because Apple is offering the upgrade FOR FREE!! Who knows how long that will last?
So far, I have only heard that AC 16 will not display the 3d model in 3d View in Mavericks. So....
Please see:
http://archicadwiki.com/OsxMavericks
Still testing here, but no problems so far (other than the issues noted by GS). I would recommend removing the GS Spotlight plugin completely until it's fixed - it was crashing at such high rate that it caused noticeable performance problems elsewhere.
Ralph Wessel BArch
Central Innovation
Hi Ralph,
Can you advise us as to how to remove or disable the plug-in? Under /Library/Spotlight I see "Graphisoft.mdimporter" ... but it's dated September 2009 and the exec inside is dated 2007. Under /Library/QuickLook I see "GSQuickLook.glgenerator" which caused one crash here ...and the exec in side is dated 2013 although the container is dated 2011.
Thanks!
Eduardo Rolon
Where can I find the plugin?
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
I don't know if this is a standard install or not, but the plugin at /Library/Spotlight/GSMDimporter.mdimporter was crashing repeatedly (and frequently). I removed it by simply deleting it (with Admin name/password). I spotted it because my crash logs were flooded with the following:
Process: mdworker [3244]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Identifier: mdworker
Version: 800.12
Code Type: X86-64 (Native)
Parent Process: launchd [345]
Responsible: mdworker [3244]
User ID: 502
PlugIn Path: /Library/Spotlight/GSMDimporter.mdimporter/Contents/MacOS/_GSSupport/TextEngine.framework/Versions/A/TextEngine
PlugIn Identifier: com.graphisoft.TextEngine
PlugIn Version: 17.0.0 v1 [4005] (17.0.0.4005)
Date/Time: 2013-10-24 13:33:19.112 +0100
OS Version: Mac OS X 10.9 (13A603)
Report Version: 11
Anonymous UUID: 09424275-2D0F-616D-8E08-E79934CCC8BD
Crashed Thread: 4
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
/Library/Spotlight/GSMDimporter.mdimporter/Contents/MacOS//_GSSupport/TextEngine.framework/Versions/A/TextEngine
pre-plugin fstype:hfs fsflag:480D000 flags:240000007E diag:0 isXCode:0 uti:com.graphisoft.archicad.mod plugin:/Library/Spotlight/GSMDimporter.mdimporter - find suspect file using: sudo mdutil -t 25970184
*** CFHash() called with NULL ***
Application Specific Signatures:
pre-plugin uti:com.graphisoft.archicad.mod plugin:/Library/Spotlight/GSMDimporter.mdimporter uuid:7ED04876-E51E-474A-99C1-2A60C76EFD0B 17.0.0.4005
Ralph Wessel BArch
Central Innovation
Thanks, Ralph. I see that one too now. The Graphisoft.mdimporter must be an old one.
Interestingly, I haven't had any spotlight crashes, but do get a Quicklook crash every time I click on a PLN with a preview panel open in Finder:
Process:         QuickLookSatellite [6632]
Path:            /System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app/Contents/XPCServices/QuickLookSatellite.xpc/Contents/MacOS/QuickLookSatellite
Identifier:      QuickLookSatellite
Version:         5.0 (521.1)
Parent Process:  ??? [1]
Responsible:     quicklookd [6597]
User ID:         501
PlugIn Path:       /Library/QuickLook/GSQuickLook.qlgenerator/Contents/MacOS/_GSSupport/GSRoot.framework/Versions/A/GSRoot
PlugIn Identifier: com.graphisoft.GSRoot
Date/Time:       2013-10-27 17:59:23.306 -0600
Report Version:  11
Anonymous UUID:  CAC5DEBB-A87F-F0DB-C306-C03AFFB9F747
Sleep/Wake UUID: 8B8BD74A-3DF8-427C-A793-D500A1FE05C3
Crashed Thread:  4  Dispatch queue: quicklookd.serialgenerator
Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Just deleting the GSQuickLook.glgenerator file in /Library/QuickLook similar to your advice for spotlight resolved that one. Not sure why I haven't run into the Spotlight crash yet...?
Thanks!
