2009-03-20 03:36 PM
2009-03-20 06:23 PM
mattsvai wrote:Hey Matts,
I am having trouble getting the measurement tool to calculate areas in 3D views. In 2D it works fine... am I doing anything wrong?
2009-03-21 12:28 AM
2009-03-21 01:34 AM
Karl wrote:Hey mate - you're on the right track. See this.
Hmmm... have to run right now, but I think I created my 3DD from a perspective view. From an axo view, perhaps the measurement tool does the right thing. But, odd that on the perspective 3DD, the dimension tool reports properly, yet measurement does not (nor is a warning issued that I am measuring from a perspective)...
2009-03-21 10:54 AM
Karl wrote:Don't measure in perspective ...mattsvai wrote:Hmmm... have to run right now, but I think I created my 3DD from a perspective view. From an axo view, perhaps the measurement tool does the right thing. But, odd that on the perspective 3DD, the dimension tool reports properly, yet measurement does not (nor is a warning issued that I am measuring from a perspective)...
2009-03-21 06:22 PM
Djordje wrote:Right. The Dimension tool does indeed get things right - perspective or not - since, as you say, it is computing distances based on model hotspots / coordinates. I don't see the purpose of 'measuring' projected distances, as opposed to model ones - and so IMHO the measurement tool should be disabled in any view in which it will not give correct results. For example, if using the measurement tool on a layout sheet, then the distance in inches / cms can be of interest for layout purposes - as opposed to modeling purposes. But I don't see the point enabling the tool to display a meaningless distance in model units on a 3DD view itself.
Dimension tool is not really measuring the distance of the two points in the projection, which the measurement tool does ... that's why it's correct in 3DD - reads the model coordinates, not the current projection of the model points.
Bottom line: you will get correct DIMENSIONS, but not measurements. Anyway - for the clarity sake, setting the ISOmetric view without any scaling is a surefire way to get it right.
2009-03-22 05:05 AM
Karl wrote:Although you do have a point, I would argue that the measurements should be correct in the 3D window. Not necessarily so in 3DD, that is a PROJECTION - a drawing, if you will - therefore not a view of the model.
Alternatively, I don't see why the measurement tool, in a model view, cannot give the same results as the dimension tool - using the model coordinates of the hotspots - in which case it could also display correct area amounts computed from those coordinates.
