2007-02-14 07:17 AM - last edited on 2023-05-23 03:21 PM by Rubia Torres
2007-02-14 04:49 PM
2007-02-16 03:09 PM
2007-02-17 09:54 PM
2007-02-17 11:58 PM
2007-02-18 05:23 PM
CAD wrote:The 2D window you refer to I assume is the plan view. There are other 2D views of the model.
It is seen in the 2d window as a vertical projection! You will not be able to get actual dimensions of this element in the 2d window!
2007-02-19 03:20 PM
Matthew wrote:indeed, i was just about to say the same. using the line you can measure on plan and section/elevation view. using the measure tool you can also measure in te 3d window (hurray for that by the way)CAD wrote:The 2D window you refer to I assume is the plan view. There are other 2D views of the model.
It appears that you haven't used the section tool yet (apologies if I am mistaken). This allows you to create vertical 2D views of the model. If you place your section parallel to the rafter you can measure its length in that view.
