Merge Meshes in 2022
Hi, is it possible to merge meshes in Archicad ? or is still problem continuing ? šŸ˜„
I made a model of land and I did extension after. I would like to merge two meshes.
If isn't possible can i get rid of border lines between two meshes at least and keeping curves lines visible?
Skärmavbild 2022-01-17 kl. 15.56.06.jpgSkärmavbild 2022-01-17 kl. 15.56.12.jpg
AC 7 - 27 SWE
MacBook Pro, M4 Pro
5 REPLIES 5
Hello Vojtech Slavik,
Do you select your first mesh, click on a peripheral segment, choose the "+" option and finally press the space bar before clicking on the other mesh ?
This method will not merge meshes but will nevertheless make it possible to recover the influence of the second mesh. Otherwise I can advise you to hide the outline of the two meshes and then to redraw in 2D the global outline of the two meshes to create the illusion of a single mesh.
Or you can create a Patch to draw over this line. I agree with you it is not a great solution but you are able to get your aim by this way.
Christophe - FRANCE
Formateur Archicad indƩpendant Ơ NANTES
Archicad 15 to 29 FRA FULL
Thanks Shristophe, this solution make just flat terrain.
It's mean that skip all the curves with highs information.
Any other ideas ?
AC 7 - 27 SWE
MacBook Pro, M4 Pro
Or course my first solution means that skip all the curves with highs information.
Did you consider my second proposition ?
Christophe - FRANCE
I didn't get it second solution. Did you mean like hidening lines by using fills and put above it ?
If is this all possibilities how to reach that how you said both solution is not elegant šŸ˜•
AC 7 - 27 SWE
MacBook Pro, M4 Pro
Hidening lines with a patch yes. The line is the problem, hide it !
It's a elegant but not a great professional solution šŸ˜‰
Christophe - FRANCE
