Merging Fills and Slabs
is it possible to merge that two objects?
Uper is a slab, and lower is a fill...
thank you
12 Replies 12
get rid of the fill and make the footing (lower piece) a complex profile. Otherwise, if you keep the lower fill you'll need to mask over the joint with more fills and lines.
Jared Banks, AIA
Shoegnome Architects
but how can i make a complex profile? i have never used this option before...
Read this recent thread:
http://archicad-talk.graphisoft.com/viewtopic.php?t=32404
Jared Banks, AIA
ok thanks...
but when i create a custom profile and draw it on the floor plan, it is invisible...
does anybody knows why?
are you drawing it with the wall tool? If so it's probably a display issue (probably set to cut only).
Jared Banks, AIA
Is it possible the wall is shorter than your "cut plane"?
Try Projected with Overhead.
lec
yeah, i figured that this is the problem...
how to do that?
Try
