Merging slab?
Found out that you can merge wall, column, and beam under complex profiles.
I wish there is a merging for slab.
For example, if there is a drop of 50mm in the slab, I would cut the area out and replace it with a slab 50mm less thicker than the previous one.
When I change the floor area, I dont have to change both area. Time is important.
Also when I copy the floor, sometimes I miss it.
Any one any clue.
2 Replies 2
Yes, but you are not wasting time changing the floor area? just kiddind. 🙂
I guess it's hard to predict all things we want to do in a project..
I think your language is not so clear on this. I am assuming by "merge" you mean the way a single profile can be set to work as a wall, beam, column or any combination thereof.
Do you mean to include slab (and perhaps roof) edges as options in the profile editor? This is a longstanding wish, but an important one. I suspect (hope?) GS may be working on it already.
