Mircea Samanta
Solid operations - copying the solid operators to a new element.
Hello to all,
I am currently having an issue regarding the solid operation tool. I have some Soil Filling to plan and eventhow i have build everything with slab tool and removed all relevant elements like foundations, stone fillings and other stuffs with the solid operation tool, my slab is no longer a solid, i can  only see the facettes. My question would be: is there any possibility to copy all operators from an element to an other element without selecting every single operator element?
Thank you in advance for your assistance.
Jeff Thompson
Short answer is no.  Not that I'm aware of.  But here is a quick way to select all of the operator objects so you can copy them...
Make sure you have all your layers turned on in your model, All Visible
Highlight your Soil Filling (Slab)
Open Solid Element Operation (SEO) Palette
With the Soil Filling (Slab) selected, Go to the Add to Selection portion of the Palette, and click on the Add Operators
Deselect your Soil Filling (Slab) from the selection by using the Shift key
Then all of your Operators will be selected
Copy as needed
You will need to SEO the new oject you create though.  The selected elements will only be assigned to the solid element operation of the previous Soil Filling (Slab).
Project Manager
Rutledge Maul Architects, PS Inc., Seattle, WA
Windows 11 Pro, HP Pavilion Gaming Desktop 790, Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz 3.19 GHz, 32.0 GB RAM, 64-bit operating system.
Archicad 28 - Graphisoft Forward
Mircea Samanta
Thank you for the solution, I have used this method previously but i was wondering if there is an alternative way to just copy the operators to another element, hence the question. Non the less, thank you for your answer.
