Mesh Intersection With other elements
How exactly do I get the mesh to intersect correctly and automatically with me slab? I tried Merge Element but it did nothing. I defined the priority of the building material of my mesh correctly...
2 Replies 2
Hi Alex
Meshes do not take part of the Priority Based Connections. So you actually have to connect the Mesh to the slab manually (right-click / Connect ...) and using the Solid Element Operations Panel.
Typically you will make the slab "dig" into the Mesh by Subtracting with upward Extrusion.
Check it here
http://helpcenter.graphisoft.com/guides/archicad-17-int-reference-guide/virtual-building/element-extras-trussmaker-solid-element-operations/solid-element-operations/solid-operation-types/
Hope it helps
Nando Mogollon
Director @ BuilDigital
[email protected]
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Then why can it be assigned a "building material"? Shouldn't it be called a surface instead?
It's just that I want to create some 3D visualizations, therefore I need to add drive ways, paths and other little things, and for each one of them, because they're supposed to be burred in the ground, I have to perform SEO.
Anyways thanks.
