Mesh Intersection With other elements
How exactly do I get the mesh to intersect correctly and automatically with me slab? I tried Merge Element but it did nothing. I defined the priority of the building material of my mesh correctly...
Hi Alex
Meshes do not take part of the Priority Based Connections. So you actually have to connect the Mesh to the slab manually (right-click / Connect ...) and using the Solid Element Operations Panel.
Typically you will make the slab "dig" into the Mesh by Subtracting with upward Extrusion.
Check it here
http://helpcenter.graphisoft.com/guides/archicad-17-int-reference-guide/virtual-building/element-extras-trussmaker-solid-element-operations/solid-element-operations/solid-operation-types/
Hope it helps
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Then why can it be assigned a "building material"? Shouldn't it be called a surface instead?
It's just that I want to create some 3D visualizations, therefore I need to add drive ways, paths and other little things, and for each one of them, because they're supposed to be burred in the ground, I have to perform SEO.
Anyways thanks.
