Mesh confusing height problem
Hello everyone..
I keep having problem with the meshes..
I create a mesh and put it on -0.40 m. for example and it goes to project zero, although above in the properties settings it keeps saying -0.40m.
why???
3 Replies 3
No problems here on AC15 and AC16. An example from AC15:
rocorona
That is the height of the Mesh Reference plane, that if often different from the Mesh surface
The mesh surface usually is not a single plane (and not horizontal), so it can't be set in the info box field.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
I havent changed anything, Ive just placed the mesh, eg 50 cm width and not changed the grips afterwards. Its a flat mesh
