Mesh from Data
Hi, there is any step by step, how you Place a Mesh from Survejors Data?
Any help will be appreciate.
Thanks
2 Replies 2
1. Select menu Design > Place Mesh From Surveyors Data > Browse for file with "xyz.txt" data > Open.
2. In the Place Mesh From Surveyors Data Window: Select Units, Placement....Define graphicaly, Input Project zero value >OK >Pick > You get the Mesh.
xyz.txt.....delete all unnecesary data from it, keep only x, y and z coordinates.
Thanks
