Mesh from X,Y,Z data in AC14?
Where is the command for creating MESH using X, Y, Z points from data loggers in ArchiCAD 14??
The picture is from AEC Magazine UK
In the 'Design' menu, third from bottom.
If you imported your work environment from AC13, you will have to add this command to the menu manually to be able to use it.
Thank you Peter. It was exactly that.
