Mesh pet palette resets to default
Hi All
I think there's a bug with the mesh tool pet palette - in previous versions of ArchiCAD the pet palette would default to the last option used - in AC17 using the adjust z-value command in plan view works fine, but when trying to adjust another mesh point it defaults to the Move node option.
Has anyone else come across this? It occurs on both PC and Mac versions(build 3002).
Or is there a setting somewhere that I'm not aware of?
4 REPLIES 4
David Maudlin
Mark:
Yes, I am getting the same behavior as you in AC17. AC16 behaves this way when editing the Mesh in the 3D Window.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
I've been informed by GS that it is a bug and has been reported previously (Developer case ref. ID: 160814). will just have to be very, very patient whilst adjusting mesh points until it's patched. There's no schedule for this bug fix as yet.
Pet Palette defaults have always been a bit variable in 3D. This has varied not only between versions but also between platforms. It has generally been better behaved (default to last tool used) on Macs than on Windows.
I reported this a couple weeks ago, they confirmed it with me while on the phone. Annoying to have to re-click the option every time.
