Mesh tool as site modelling
I have been utilising the mesh tool to model site terrains from detail surveyor drawings taken relative to a datum point;
Are there some practical shortcuts to the otherwise time consuming process of entering survey level heights individually or as a group;
What about cutting out an area within a mesh - is it possible to retain the levels of a mesh and just divide it up into smaller parcels? Great tool - but I suspect I am under-utilising its potential.
Is there a tutorial on the mesh tool for this scenario?
I have not found one yet.
4 REPLIES 4
Djordje
There are few around here, check the Tips section and ArchiCAD Wiki.
Also, take a look at ArchiTerra by Cigraph.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Does any one have a link to further info on producing a grid of levels, I've used the mesh tool before and am familiar with adding Z heights. Is it possible to produce contour lines ?
David Maudlin
Jus:
To extract contour lines from a mesh, see this thread:
Getting contour lines from a mesh
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Many thanks.
Has anyone used Archicad for serious cut & fill analysis; is it possible ?
