Mesh triangulation
Hy, is there a way to "retriangulate" the mesh?
I'm getting (see pic) and I want it to be smother.
Thanks.
4 REPLIES 4
What you can do is you can draw ridges and set their height.
So if you want to see a given ridge, place it into the Mesh explicitly.
Those will take precedence and ArchiCAD will triangulate the rest.
The minimal solution might be to put one or two points in the middle of the flat area. This should force the triangulation you are looking for without adding visible contours. As I recall th trick to adding single points is to draw a single linen segment as a contour an then drag one endpoint onto the other.
Thank you, both methods did the trick.
Easier than I thought.
David Maudlin
A faster method is to select the Mesh, have the Mesh Tool selected, select the Polygonal Geometry Method, and click twice on the spot where you want to add the point.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
