2015-12-09 08:07 PM
2015-12-09 09:58 PM
rob2218 wrote:You've probably worked this out by now, but symbol line types get added to the bottom of the list, not in alphabetical order.
first off....I can't find it on the list of "linetypes"?
where does it reside?
2015-12-09 10:41 PM
2015-12-09 10:44 PM
2015-12-09 11:57 PM
rob2218 wrote:When I set the dash to 0.4mm that was 1/100th of the size of my symbol. I would have thought it would need to be actual size, not 1/100th. This did not change when I selected the line segments from a 1:1 view or a 1:100 view. This confuses me.
well...and see your "dash' dimension is 0.40 which equates to mine that is 1 inch.....
I set my "dash" parameter to 1" in my editor when I was creating the linetype and it didn't make it read connected nor could I see it like I see yours.
dunno
2015-12-10 12:12 AM
2015-12-10 12:25 AM
2015-12-10 01:18 AM
2015-12-10 01:26 AM
2015-12-10 01:26 AM
2015-12-10 04:29 AM
rob2218 wrote:No. You can pick up the line elements used with the "Copy" button in the Line Type setting, paste to a plan view, edit, copy from plan view, go back to Line Types and Paste back into your symbol line, but you can't edit directly within the Line Types dialogue.
is there anyway to "edit" the linetype once it's created so you can move the lines in the editing box?
