Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
2012-10-2503:49 AM - last edited on 2023-05-2304:34 PM by Rubia Torres
I started creating a space using doors and windows from the Object library that I guess came installed with the program. Well I downloaded a table from the internet and now the original library is gone - or doesn't work - or I don't know! So now if I choose Object I get no doors, no windows, etc. Even if I search it comes back with no results.
The only suggestion I could find online here is to maybe consolidate libraries and that would solve the issue. NO. No matter how many libraries I add to the manager, the consolidate icon never even shows up.
I'm dead in the water right now. I've got midterms due this Monday and both classes I'm taking require ArchiCAD to complete the projects. HEEELPP!!!
Also, I even tried removing the program and reinstalling thinking that would bring all the defaults back. NOPE. The issue seems to follow the file? Although I opened a new file and still couldn't access the objects from the beginning.
I'm using ArchiCAD 16 Education (the only one I've ever used) on a Macbook Pro.
Doors can only be accessed in the library by using the "door" tool.
Windows with the "window" tool.
Sounds like you are using the "object" tool which will allow you to see the table you downloaded but not the doors or windows.
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
