Pendu wrote:
hi, I have a problem using "FILLS" in AC12. I noted that in "OPTIONS, ELEMENTS ATTRIBUTES, FILLS TYPES" I have only SOLID fills.
Do you know where are the other options like VECTORIALS or SYMBOLS fills ? Thank you
There are several options:
1. Use Attribute Manager to import Fills from another Project File you previously used.
2. Use Attribute Manager to import Fills from the default ArchiCAD Template File.
3. Start a brand new project based on the default ArchiCAD Template File. That file will have its complete attribute set loaded and set to their default values.
