Missing line of intersection between objects
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2013-04-29
03:37 PM
ā2023-05-23
04:30 PM
Rubia Torres
ā2013-04-29
03:37 PM
IC
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2013-04-29 03:50 PM
ā2013-04-29
03:50 PM
Just a guess - your roof is continuous through your chimney. You have two options.
1. cut a hole in the roof for the chimney to pass through
2. use SEO to remove the roof with the chimney as the operator and the roof as the object.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2013-04-29 07:10 PM
ā2013-04-29
07:10 PM
While some other applications seek out and represent every edge, in Archicad, merely colliding two elements doesn't make an intersection.
Even though it photo renders correctly most of the time, you still need to assert where edges happen as Erich instructs.
Dwight Atkinson
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2013-04-29 10:48 PM
ā2013-04-29
10:48 PM
Chimney might not be enough. It will leave roof surface inside the chimney. ;D
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2013-04-30 01:00 PM
ā2013-04-30
01:00 PM
Thank you for the reply. I found it more practical to use the SEO function.
IC
