Missing options in SAVE SELECTION AS
Hello, I am student still learning ARCHICAD.
I am currently starting with ARCHICAD 20 and I wanted to create curtail wall from panels that I make. I watched videos but in my menu some of the options are missing. Anyone knows how to solve my problem fix it ?
I am attatching printscreen[/img]
Go to the Work Environment Dialog, and apply the Standard Profile.
Or, you could set only the Toolbars and Menus back to the default by going to Command Layouts Schemes and applying the "Standard Commands" Scheme.
Then all default menu commands should be there in your menu.
