‎2007-02-11 08:44 PM
‎2007-02-11 10:51 PM
mariogomezcervantes wrote:The stamp that your zone uses is set in Options>Element Attributes>Zone Categories... At the top select the zone category your zone belongs to and then under the 'Edit Selected Category' panel, you will see a button with the Zone Stamp for that category. If the stamp name is preceded by the word 'MISSING' then that means you haven't got the stamp loaded in your current library. In that case you'll then need to OK that and go to File>Libraries and Objects>Library Manager... find the appropriate library (probably ArchiCAD Library 10) and add it to your Active Libraries.
Hi everyone, I am working on a school project, just turn from archicad 9 to 10, I have the pro version, when I open archicad, i get a message saying the zone stamp tool is not loading, when I use the zone tool, I don't get the info (area, name, etc), do I have to load it? Is something missing I have to download? Hope to get a reply before my presentation, thanks!!
‎2007-02-12 05:24 AM
