Modeling Masonry Wall Detail
drh64
Can someone suggest the best way to model brick profiles as shown on the attached file? Do I break the walls up into separate elements?
Dwight
Each depth of element : running brick, mortar and soldier units [deeper] can be done with separate complex profiles. One for each thickness
Once the elevation-traced fill is created, make each complex profile wall perpendicular to the massing wall where the window is.
complex purlpldabbldoodle
It will be satisfying and beautiful.
Dwight Atkinson
drh64
Thanks Dwight!
How about the arch detail - window component or a complex profile?
Dwight
Part of the profile.
The window won't cut through this profile - the profile must be applied on the face of an existing wall like a cardboard stage decoration.
Dwight Atkinson
