Modeling facade between arches
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-11-29
04:09 PM
2025-01-31
01:27 PM
Molinda Prey
I came up to a point where I have to post this problem of mine in the forum and ask for your opinion. The case concerns the modeling of a special window / facade.
As you can see in the image, the space between the arches will be filled with a facade. It is stretched between two stories.
In the first case we used the facade tool to model it but it failed the moment when we were not able to “bend” the element accordingly to the small radius of the arches. The façade tool or its element simply cannot produce rounded profiles.
Therefore we took the step to model the whole element as a window. The disadvantage of this approach is the number of libraries that will need to save, since most of the arches are not the same and many have doors or windows in multiple positions. Managing them and applying changes will be a real challenge.
So here I am, asking for your help or opinion of which solution would you implement to model these elements or maybe you have a better solution?
Currently: Archicad 26
User since Archicad 6.5 (2001)
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-12-17 11:09 PM
1. draw the window shape in section with poly line
2. use Curtain Wall tool ( the boundary one ) with magic wand tool
3. draw morph in section , again magic wand tool around poly line - extrude in 3D
4. use SEO and hide morph on a layer
Cheers Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-11-29 04:20 PM
AC26 (since AC6.0), Win10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-12-17 07:41 PM
Richard wrote:we tried the Cadimage, but it did not help solve the case.
This looks like something that the Cadimage Door/Window tool would be perfect for. You might try downloading a free trial and see if it helps.
So in the end we ended up modeling the arch with mutliple nodes, just to produce a smooth curve. This is a tip I got from a friend of mine. It is till not the perfect shape, but with approx. 15 nodes, the segmentation is not visable in scale 1:50.
I already talked to Graphisoft to implement this option in their next version. They did a great job with the CurtainWall Tool, but they somehow forgot that there are also curved profiles in reality
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-12-17 11:09 PM
Cheers Carsten
www.asmtechbase.com
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-12-20 09:11 PM
AC26, iMac
User since V5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-12-26 11:21 PM
It is much easier to have a "hidden" layer then to keep copies of designs and way faster. The wall is a perfect example, morph can't show the walls composite construction fills , or the morph won't be able to "cleanup" at a corner intersecting with another wall, etc.
www.asmtechbase.com
