Milan
Modeling sugestion
Hi everyone.
I have this particular structure to be modeled, but is a bit harder than simple column and beam method, because is curved all the way (as you can see from the top view). wall tool neither work, and maybe shell is only valid, but not sure how... any ideas? i can import as a object, convert it into morph but not sure if thats good, especially when construction stage is ready.
Thanks!
13 Replies 13
Milan
thanks a lot! I created it wih one piece shell, and multiple holes, it worked... 🙂
Is modeled, for concept stage thinks is ok.
Thanks once again for your help!
Milan
Milan
Is a structure, and is now just conceptual stage, and whatever is ok. But when construction stage is there, i may need to convince my boss to change that! Is a hell for a execution!
Cheers!
Milan
Botonis
Mentor
You may add it as a solution then for the forum.
Milan
ah, sure. i thought i did it yesterday!
