Modeling sugestion
Milan
Hi everyone.
I have this particular structure to be modeled, but is a bit harder than simple column and beam method, because is curved all the way (as you can see from the top view). wall tool neither work, and maybe shell is only valid, but not sure how... any ideas? i can import as a object, convert it into morph but not sure if thats good, especially when construction stage is ready.
Thanks!
13 REPLIES 13
thanks a lot! I created it wih one piece shell, and multiple holes, it worked... 🙂
Is modeled, for concept stage thinks is ok.
Thanks once again for your help!
Milan
Is a structure, and is now just conceptual stage, and whatever is ok. But when construction stage is there, i may need to convince my boss to change that! Is a hell for a execution!
Cheers!
Milan
You may add it as a solution then for the forum.
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
ah, sure. i thought i did it yesterday!
Setup info provided by author
