Modelling complex objects -- translation in plan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2006-05-22
09:09 PM
‎2023-05-23
05:16 PM
Rubia Torres
Thanks,
John Wissinger
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-05-22 09:11 PM
Thanks,
John Wissinger
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I would say that in order to make it work, you need to:
- build everything with walls, columns, beams, and roofs,
- make sure your floor plan cutting plan is set to
- make sure all the modeled elements are set to cut properly
Other than that.... there's not much more I can recommend.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-05-22 09:40 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-05-22 09:59 PM
How do you create walls that slope, have their sides angled, and have their tops angles as well....so it is essentially a sloping wall, except I need the ability to move the edges of the wall around.
John
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-05-22 10:21 PM
I know the polygonal walls and profiled walls cannot slope interactively or I would have recommended them, and I cannot seem to figure out a way to slope the ends of the walls...
Welcome to the "Archicad's modeling limitations" realm
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-05-22 10:45 PM
AC V6 to V18 - RVT V11 to V16
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-05-23 05:12 AM
TomWaltz wrote:As usual, I would reccomend working in the 3D window to the same purpose. The nodes are live, you can change the slope of the wall or any of the side faces (depends on the geometry, of course) in it, and you immediately see what has been done. If you think in parallel cuts, then as Tom said, use a S/E window.
If you're using 10, the easiest way to slope a wall that I know if is to cut a section through it and use the Pet Palette of its top corner to slide the wall back.
Slicing off the top of the wall is still a case of:
- using a roof plane as a cutter
- using SEO
Add to taste and situation ...
Plan representation in 10 is a VERY different animal than in any version before - it depends in the height of the cutting plane, the position of the wall relative to the current storey, the way that the wall is displayed. Takes some time to get used to ...
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-05-23 05:13 AM
Rakela wrote:He was being nice ...
do u really need to get so sharp ??
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-05-23 12:44 PM
Rakela wrote:When "Modeling Freedom" is one of the hot selling points of Archicad 10, I don't think it's "sharp" to note where it fails to meet expectations.
Yes, there are a lot of really great modeling features (along with other types of features), but there is still not "modeling freedom." Try placing a profiled wall that curves in plan, then tell me how much freedom you have in modeling.
