Arcadia
Modifying elements in elevation views.
Since going to v13 I notice that whenever I modify an object in an interior or exterior elevation it reverts to a wireframe view (the object only not the entire elevation). This fixes itself when you update/redraw the view but it is a little annoying. Any idea why this is happening?
V12-V27, PC: Ryzen 9 3950X, 64g RAM, RTX5000, Win 11
4 Replies 4
Do you have "Update Autorebuild Model viewports continuously" (or the AC13 equivalent) turned off? It used to be in Options> Project Preferences> Miscellaneous but may have moved. I ALWAYS have that setting turned off otherwise you're forever waiting for the model to rebuild after every change. I found that annoying and prefer to rebuild when I want it to.
Arcadia
This menu item is not in the project preferences tab and I can't find it anywhere else either.
It is now in the More Options of the User Prefs in the Work Environment.
Arcadia
Cool that has fixed the problem for me. Thanks.
