Module Orientation and fixed-angle elements
Laura Yanoviak
I'm a little confused by the Help menu concerning fixed-angle elements within modules. First, it says that Labels will retain their rotation angle; then it says you can adjust the angle of fixed-angle elements to reflect module rotation: "If you do not want module angles to be fixed, and you prefer them to follow the module's rotation as specified in the Orientation field..."
1. Can you or can you not make Labels rotate with the module? Currently, I'm having to create two modules for each condition -- horizontal and vertical -- so that the Labels will read correctly.
2. What the heck does "...do not want module angles to be fixed, and you prefer them to follow the module's rotation..." mean? Of course I want the module to follow the module's rotation.
(working in AC11)
4 REPLIES 4
Erika Epstein
If you UNCHECK the box, labels and zone tags will stay at the same angle they were originally placed. If you check that box, label text and zone tags will rotate with the module.
-I wish we could separate the choice for zone tags and labels.
-I wish one choice would be to allow us to individually rotate label text as needed when rotating a module.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Laura Yanoviak
So an exception would be Labels placed with "Use symbol arrow" aka without a Pointer. I think the Labels' orientations should behave the same regardless of the "Use symbol arrow" setting.
Laura Yanoviak
OK -- I unchecked "Use symbol arrow" and assigned the Pointer an 'invisible' line type and made the arrowhead small and white. Yet another goofy work-around...
Erika Epstein
I'm not sure which label you are actually using, so this may or may not apply.
One of the somewhat counter-intuitive settings is the 'USE SYMBOL ARROW'. For the type of symbol you show, NO arrow is the symbol arrow so checking that box will turn OFF the arrow and its lead.
HTH
Just logged in to post and I see we were at the same point.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
