Module file
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2007-04-27
10:42 AM
‎2023-05-23
05:09 PM
Rubia Torres
‎2007-04-27
10:42 AM
This is working when Im doing it object by object but not in one single operation. Is there a better way to do it?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-04-27 10:59 AM
‎2007-04-27
10:59 AM
Mallsten wrote:You can't move different objects (lines, circles ... ) to a layer at the same time with only use layer button. With layer button you only change layers of the objects that are the type you se in your setting dialog button.
I've got a 2d dwg which I want to create a module file from. I select everything and change layers to place everything in the ArchiCad layer, but only a few objects move to the ArchiCad layer.
But if you instead use "Layer - Edit selection set dialog", the button next to Layer, then you could do it, open this dialog and change the layer inside it.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-04-27 06:47 PM
‎2007-04-27
06:47 PM
TurboGlider wrote:The "hammer in the square" button adjacent to the Layer button in the Info Box.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-04-28 07:06 PM
‎2007-04-28
07:06 PM
If you use Ctrl+T (or Cmd+T) to change layers it won't work ...but if you do Ctrl+Shift+T (or Cmd+Shift+T) it does work.
