Learn more
Module file
I've got a 2d dwg which I want to create a module file from. I select everything and change layers to place everything in the ArchiCad layer, but only a few objects move to the ArchiCad layer.
This is working when Im doing it object by object but not in one single operation. Is there a better way to do it?
3 Replies 3
You can't move different objects (lines, circles ... ) to a layer at the same time with only use layer button. With layer button you only change layers of the objects that are the type you se in your setting dialog button.
But if you instead use "Layer - Edit selection set dialog", the button next to Layer, then you could do it, open this dialog and change the layer inside it.
Laura Yanoviak
The "hammer in the square" button adjacent to the Layer button in the Info Box.
If you use Ctrl+T (or Cmd+T) to change layers it won't work ...but if you do Ctrl+Shift+T (or Cmd+Shift+T) it does work.
