Marky
Modules' usefulness
ArchiCAD Help says (p.811 in Polish ver.) that when trying to insert a module which has more storeys than in the project, exceeding story of the inserted module won't be inserted.
Really?
In my case AC behaves little bit different - inserted building (left one) has all its storeys but is all messed up, since its slabs are lined up with the project's storey settings. Different storeys names don't help much, neither the omitting the slab setting in the storey setup window.
Is there anything else than inserting the other building with the larger number of storeys as an object?
Thanks,
Marek
AC 6.5, 13 - 19 Pl, OctaneRender for ArchiCAD, MoI 3D, Blender; W7 Pro 64;
i7-4790K/32 GB; GTX 980/4 GB
10 Replies 10
And now I find this:
forum.bobrow.com/forum/showtopic.php?tid/151/post/last/
..which is the best and most comprehensive summary of all the relevant issues that I've read. Which is typical of Eric. I've been getting my head around his excellent MasterTemplate system (http://www.archicadtemplate.com/) and his advice and support when I've had questions is always clear and detailed.
