Morph - Convert to Wall
Hi there
Couple of quick questions regarding morphs in ACAD17 -
_Can you create a morph then change one of its faces to a wall? If so how?
_Can you split a single face of a morph? If so how?
Many thanks.
You cannot convert a morph to anything else (other than saving as an object).
Use the pencil pet palette option to draw a line (or other shape -Morph Tool options in Info Box control what is drawn), like in SketchUp.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks Karl.
