Morph Editing: Push-Pull (AC20)
Hi guys.. noobie here...
having problem with the "pushpull" with morph.. im using ver.20 i drew a circle flat using morph tool, but when i tried to pick the face and push-pull it does not work, cant pull it.. as where if i create a cube from morph tool..then try to push-pull any of the 6 sides it does work smoothly.. also notice the sub-palette doesnt show the push pull icon...when i do the right-click cant see it..
thanks in advance...
12 Replies 12
No you have to click on the hotspots or an edge or the surface in order for the pet palette to appear.
You will get different options in the palette depending on what you click.
felcunha
Make sure the magnet is activated when clicking on an element (see my previous post). It will show the pet palette when clicking on the surface, although you will not have all the editing possibilities.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
thank you all..for helping out...learned a lot...
cheers.
