2018-02-23
02:15 AM
- last edited on
2023-05-24
07:24 PM
by
Rubia Torres
2018-02-23 07:16 AM
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2018-02-23 07:54 AM
Lingwisyer wrote:thanks Ling...
While the circle is a morph, it is still a 2D object so it's volume can't change... Could you just model a cylinder with a column then convert that to a morph?
Ling.
2018-02-23 08:10 AM
2018-02-23 08:36 AM
2018-02-23 09:21 AM
2018-02-23 10:02 AM
Barry wrote:
So long as you are selecting the morph face (and not the perimeter or entire morph) then you should be able to push/pull.
If you select the perimeter you will be able to 'TUBE' it.
If you select the entire morph (not the sub-elements) you will not have either of these options.
2018-02-23 10:09 AM
xrowdac wrote:
BTW any idea or Keyboard-shortcut on how to display this sub-palette menu during selection... do we always need to "click" those corner hot-dots (grips) to display this sub-palette menu (editing),,
2018-02-23 10:11 AM
2018-02-23 10:15 AM
