Morph Tool Question
Where two adjacent faces have a common edge, we can CURVE and MERGE the edge. Does anybody knows how to select the radius of the curve? or what the default radius dimension is?
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
If you use the fillet/chamfer option in the pet palette you will get a dialogue box where you can set the radius.
