2020-01-10 07:37 PM - last edited on 2023-05-23 02:07 PM by Rubia Torres
2020-01-11 02:47 PM
2020-01-11 03:16 PM
Bishoy wrote:While you cannot put a Window in a Morph, you could cut a hole in the Morph, place a Wall the size of the Window there, then place the Window in that Wall.
Problem number 1 is that i wanted to ask if there is any solution to put a window in a morph.
2020-01-11 03:47 PM
LaszloNagy wrote:
It is not possible to place a Window into a Wall.
Doors and Windows can only placed into Walls, they cannot stand on their own. This is why they do not even have their own Layer.
About the Roof: how do you want to cut it? Do you want the Roof Eaves to be vertical and its outside face flush with the Wall's outside face?
2020-01-11 04:05 PM
David wrote:Even if it is a slanted window ?
David
2020-01-12 03:24 PM
Bishoy wrote:Yes. In the Wall Tool settings > Geometry and Positioning > select the Slant wall option and set the angle. Then in the Window Tool settings > Preview and Positioning > select the Opening Plane: associated to Wall option
David
2020-01-13 04:09 PM
2020-01-13 08:18 PM
