KeesW
Morph training
I am following the instructions in Archicad Training Series volume 2 Conceptual Design and am stuck on the page 9 - only the second page of the tutorial! After creating the 40000x28000x1000 morph base, I am supposed to draw a snap guide from the bottom left corner on top of this first box. When I do this I am drawing another morph box, and not a blue dotted line as per the tutorial. What am I doing wrong? Is there a step missing in the tutorial?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
4 Replies 4
Make sure you hover over the corner & allow the blue circle to finish before you type in the value.
It's also worth noting that you can speed up the appearance of the circle by typing "Q".
Richard
AC26 (since AC6.0), Win10
KeesW
I have tried hovering and using 'Q' but still aren't getting the blue circle and line. Is there a setting I need to switch on to make this happen?
David Maudlin
Kees:
A few things to check:
Are Snap Guides and Snap Guides and Points turned on (these are On Screen Display Options)?
In Work Environment > User Preference Schemes > Input Constraints and Guides > Highlight as snap reference after: is this set to a high number of seconds?
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
