Morphing Stairs
I need a quick way to morph stairs that I have created. I made simple, straight, 9 risers that need more wire cable than offered. I also need the railing to be wood and square, not round.
Thanks,
Andrea
1 Reply 1
Select the Stair and use the Design\Convert Selection to Morph(s) menu command. This will convert the Stair to a Morph and then you can freely modify its geometry.
