2014-09-2304:05 AM - last edited on 2023-05-2407:27 PM by Rubia Torres
Morphing Stairs
2014-09-2304:05 AM
I need a quick way to morph stairs that I have created. I made simple, straight, 9 risers that need more wire cable than offered. I also need the railing to be wood and square, not round.
Select the Stair and use the Design\Convert Selection to Morph(s) menu command. This will convert the Stair to a Morph and then you can freely modify its geometry.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac29
