Learn more
eddybern
Move or rotate multiple Design Options
Hi everyone,
I've been experimenting with the new Archicad 27 feature Design Options and now I find myself in the position of having to move my model, whit all its Design Options, somewhere else.
Is there a simple way of doing so or am I destined to move each option individually?
Thanks!
2 Replies 2
MarcinK
Same problem here, any solution?
runxel
No real solution, but the workaround is to make a seperate set for each option.
Of course that's a bit tiring if you have a lot of options, but certainly easier than to move things seperately.
