‎2014-01-0303:21 PM - last edited on ‎2023-05-2302:32 PM by Rubia Torres
‎2014-01-0303:21 PM
Multi-plane roofs again.
When I stretch the horizontal ridge of the roof, the Tracker has the option to input the roof pitch for the desired roof plane. But it is only in degrees, while the roof pitch is usually measured in percents!
The angle measurements in the Tracker should correspond to the selected measurement method in the Roof tool!
I believe this is a good wish and you should post it in the wishlist area. It involves adding programming to accommodate multiple standards worldwide. For instance in the United States we use Rise over Run instead of decimal angle or percents. Right now the tracker is using the available code. I can pose it to the designers to add the option though. Like you state, it would be nice if it corresponded with with parameters in the roof tool.
