Multi-plane roofs again.
When I stretch the horizontal ridge of the roof, the Tracker has the option to input the roof pitch for the desired roof plane. But it is only in degrees, while the roof pitch is usually measured in percents!
The angle measurements in the Tracker should correspond to the selected measurement method in the Roof tool!
