2004-03-18 05:56 AM
2004-03-18 10:26 PM
Sergio wrote:I've used SEO on a part of a building and then hotlinked it so it could be duplicated in other areas of the building. It worked. Although the hotlink was within the same project I cant see why it wouldnt work going to another project.
Keep in mind though that if you do use modules (and I guess hotlinks also), the SEO information apparently doesn't transfer. See this discussion athttp://archicad-talk.graphisoft.com/viewtopic.php?t=1928&highlight=
Then again, maybe/hopefully hotlinks are different.
2004-03-20 03:37 AM
