2014-07-07
12:27 PM
- last edited on
2023-05-23
04:25 PM
by
Rubia Torres
2014-07-08 03:18 PM
ejrolon wrote:I think this is the debate where nobody will be able to decide which is better, because both ways have/had their plus and minus points.zeropointreference wrote:+1
… Not only that, but I am sooooooo sick of that orange dot appearing under my pointer or over hotspots.
2014-07-08 07:25 PM
2014-07-09 01:12 AM
David wrote:Correct indeed.sinceV6 wrote:The Drag step is needed for elements that are already placed and need to be moved. Certain elements with an anchor point (Objects, Columns, Hotspots) can be placed directly using this method, no need to place then Drag into position.
What David Maudlin said. Use Special Snap Constraint. IT IS what you are trying to do... just instructions missed the drag operation step:...
David
2014-07-09 09:51 AM
2014-07-09 02:38 PM
zeropointreference wrote:I think debate is fine. No problem with that, good to hear different viewpoints.
Sorry, I wasn't try to debate you. There are plus and minus points to both and I will concede the new system provides a lot of usability.
The problem with the orange ball is something that can be fixed but I have to agree with ejrolon the ball appearing over hot spots is worse than under the pointer but both situations are frustrating.
